ONEX #54 Web Site
Date:  4-9-2013
Number of Hours:  1.00
Manual Reference:  ACV-R02
Brief Description:  Throttle and fuel runs
Fitted the starter and AeroInjector. The instuctions indicate the carb should be oriented "parallel" to the airframe. For clearance it looks like I'll need to install the throttle cable with a 180 degree turn because of the interference of the nose gear assembly. As oriented in the photo, there is no noticeable increase in cable friction.
Also started looking at the fuel line routing and fitting requirements.
Thottle cable entrance forward
Potential throttle cable run
